Who's wrong? Energy Susp or Internet Racers Supply
Old Mar 5, 2001 | 07:09 AM
Belker's Avatar
I have a '91 RS and want to replace the front sway bar bushings and end links with Energy Suspension ones. I measured my bar and believe that it is 30mm (although it is rusty and hard to be extremely accurate).
The Energy Suspension catalog website, under Camaro 82-92, lists a 30mm swaybar and offers part #3-5159. And lists endlink #9-8117.
However, the Internet Racer's Supply website, under Camaro 82-92, lists ES #3-5163 for a 30mm front swaybar bushing and #9-8125 for endlinks.
Neither, Summit or Jegs offers any of these part numbers in their printed catalogs.
Who do I trust? I would guess that ES has the best info., but everywhere I look (about 10 differnet places) somebody is telling me different part numbers.
How important is it to get the correct size? What if the bushing is 1-2mm too small? What if it is 1-2mm too big?
Old Mar 5, 2001 | 11:42 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
IRS is wrong, they're listing parts for the 4th-gens. You can order these parts from Summit or Jegs even though they aren't listed in their catalogs. I've done that several times when I've found a part I wanted in the manufacturer's catalog and it wasn't listed in Summit or Jegs.
It is -very- important to have the right size. You could damage or destroy parts in your front suspension if they're not the right-size parts, not to mention your swaybar wouldn't work very well if the bushings weren't holding it in place...
Greg Westphal
'87 IROC 305TPI/A4
Old Mar 5, 2001 | 02:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I believe a 91 RS would have a 32mm front sway bar, but you measured yours, so I could be wrong. My 92 RS was 32mm, its now 36mm.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 6, 2001 | 07:16 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Summit and JEGS don't print every item they stock in their catelog....remember that...i'm sure they carry your part
Originating member of the SJNEP Crew "Welcome to Understated Sounds and Performance"
Rice..It's whats for dinner!
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Tony
Check out www.transamgta.com
"What does not kill us only makes us stronger"
Old Mar 6, 2001 | 10:17 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, you gotta call Summit for a part. I looked them up at their website- remember, you need to put a "color" character after the part #. So Summit thinks the Energy Suspension #3-5159 is really ENS-3-5159R (r for red, b for black, etc).
As per end-links, It's been a while, but I think the 82-92 f-bodies were spec'd for ones with a 2 5/8" sleeve length.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 7, 2001 | 02:34 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
My 1991 RS has a 34 mm front sway bar. The RPO code is F41. Check for a blue plastic tag on the sway bar. I guess due to the low mileage on my car the blue tag with part # was still on there and it turned out to be 34 mm.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
