Front spring removal...
Old Mar 9, 2001 | 05:49 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Can someone tell me; is it easier to remove & replace the front springs with the engine IN the car or with the engine removed...I need to do a spring swap AND engine swap but don't know which which way is easiest...with the weight of the engine compressing them or not...Which to do first ??...
'83 Trans Am clone;
700R-4, 3.42:1 rearend,
'84 Z-28 suspension, dual snorkel H.O. air cleaner, H.O. exhaust manifolds & system, 180* 'stat, stock ECM. Awaiting 355 swap with CompCams 212/218 --.444/.444 -- 110* LSA
Old Mar 9, 2001 | 08:42 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Couldnt you just use a jack?
I beleive that would take to weight off of the springs!!!!
no prob....
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Mar 9, 2001 | 09:35 PM
KamaroZ350's Avatar
Car: 2008 Jeep Wrangler Unlimited
Take it out!!!!! I tryed replacing mine with the engine in and it was impossible!
1991 Z28 Camaro L98
5.7L T.P.I
Blk ext/grey lthr int
http://www.iroc-z.org/albums/KamaroZ91/
http://www.fbody.com/members/KamaroZ350/
Old Mar 9, 2001 | 10:28 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
??? the weight of the engine doesn't have anything to do with it - unless you're gonna do it with the front end on the ground and I'd like to see that. The only thing that holds that A arm up and keeps that spring from popping out of there is the ball joint where it connects to the steering knuckle. You have to use an internal coil spring compressor to remove your springs - safely, that is. If you don't, good luck to you.
KAM
Old Mar 9, 2001 | 11:30 PM
T.L.'s Avatar
Well OF COURSE I would jack the car up...I figured that was a GIVEN...I just wondered if it was easier to compress the spring (WITH THE SPRING COMPRESSOR) with the weight of the engine already partially compressing the spring....maybe it was a dumb question...
'83 Trans Am clone;
Old Mar 10, 2001 | 07:44 AM
Car: '91 Z28
Axle/Gears: 323's
No, it wasn't a dumb question - maybe I just misunderstood you, cuz it kinda sounded like you were gonna just try to get them out without a spring tool... Sorry... So back to your question, Obviously you're going to have to get under the car to work that tool in there, and it can be a pain, if you have the car on jackstands, and then jacked the A-arm to partially compress the spring, that probably would be easier than if it was fully extended. I don't know how much room you would have to work the claws of the compressor, though... Even so, it's not that hard to do it, getting the claws to stay where you want them can get frustrating at times, but other than that, I just cranked the nut on the tool with a 1/2" ratchet and it only took a few cranks. Getting the tool off the spring once you get it out can be a royal pain, too... Well, I hope I've helped you some - in a nutshell, I don't think it's any easier either way, cuz with the tool you have to use, you'll have 'em out in no time. Good luck with it!
KAM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
