HELP! i need some info on pulling the k member!
Old Jun 8, 2010 | 12:28 AM
Murphy-Iroc-87's Avatar
Car: 1987 Chevy Iroc-Z Z28 Camaro
Engine: 357CI L98
Axle/Gears: 2-77 =[
Alright guys. so im pulling the k member! yay me... lol so i have an 87 Iroc-z 5.7 TPI. I just rebuilt the motor not even 1000 miles ago, and the oil pan gasket is leaking. which goes to show that using the 4 piece oil pan gasket is bullshit. at least in my opinion. so there are 2 ways to pull the pan. 1 pull the motor. or 2 pull the k member. well i know pulling the motor might be easyier on a stock car well my exhast flanges are welded. so cant remove the headers with out cutting. (previos owners bright idea) bolts are a bitch to get off. have to remove the oil pan dipstick holder... spark plugs, wiring harness. ect.. so im going to pull the k member. so can someone help me out here im new to suspension. just a walk threw or something. i dont even know where to start.?
Old Jun 8, 2010 | 01:05 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: HELP! i need some info on pulling the k member!
Disconnect the motor mounts and lift and support the engine from the top. Disconnect the steering linkage and brake lines. Disconnect the ball joints and remove the springs (you'll need a spring compressor to get them back in). Disconnect the sway bar if equipped. Remove the 6 mounting bolts and the k-member is out.
Probably easier to just pull the engine and reinstall it properly.
Old Jun 10, 2010 | 10:50 PM
Pocket's Avatar
Car: 91 Trans Am
Its a job to say the least
https://www.thirdgen.org/forums/ltx-...d-oil-pan.html
chazman
Aug 28, 2018 03:25 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
zayne0
Aug 24, 2015 07:22 PM
chazman
Aug 22, 2015 02:01 PM
