Why does the Chiltons Manual say
Old Mar 7, 2001 | 10:31 AM
bhaas's Avatar
to remove the coil springs before the torque arm. If the torque arm is removed first, vehicle damage will result. How is that?
And then it goes on to say remove the track bar mounting bolt at the axle assy and take off pretty much everything. Is this right? I can just jack up the car and take it off without all that hassle. I've never done it but it looks like I can. Is the book wrong? Sure appears to be. Please enlighten me.
Thanks...
Old Mar 7, 2001 | 11:01 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The coil springs put a downward force on the back of the axle. (If you look underneath, you'll see the rear spring perches are located "behind" the rear lower control arm attaching points.) This makes the front of the axle want to swing up. (The axle pivots on the rear-lower-control-arm-to-axle bolts.) The torque arm's attached to the front of the axle, so it will also swing up, and hit the floorboards.
You don't need to remove the track bar to remove the torque arm.
Why do you want to remove the torque arm?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 7, 2001 | 11:16 AM
bhaas's Avatar
I don't want to remove it. I was just reading some things about the LCA's and saw that. Just didn't sound right.
Brad...
Old Mar 8, 2001 | 08:25 AM
bhaas's Avatar
Brad...
Old Mar 9, 2001 | 12:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh, okay. You'd have to pull the springs anyway before doing the rear LCA's, otherwise the axle will twist a bit, and you'll have a hard time aligning the LCA bolt holes.
Old Mar 12, 2001 | 12:19 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You don't have to remove the springs to change the LCA's. Just block all the tires and do one at a time. If the axle moves too much, put the rear most bolt in, put the tire on, lower the car and rotate the tire, and then put the other bolt in.. thats what i did.
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
