Do I have to change the struts when putting lowering springs?
Old Mar 8, 2001 | 02:19 AM
voltran's Avatar
Old Mar 8, 2001 | 08:54 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
if you still have stock struts i would recommend it. I did when i installed my edelbrock springs and it made for a much better ride. get the KYB GR-2 struts there reasably priced but there much bettter than stock and they will help out in the stibility dept. one more thing you might want to be aware of is if you install lowering springs you will have more whell hop unless you either get a relocation bracket or get aftermarket LCA's .
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , SLP boxed LCA's and panhard bar, ascd ram air hood, Z28 spoiler, white guage faces.
Old Mar 10, 2001 | 03:28 AM
voltran's Avatar
I'm kind of new to the suspension/Chasis thing. Could you please explain what whell hop and LCA's are ?
Old Mar 12, 2001 | 12:26 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Wheel hop is when you floor it and the rear loses and gains traction very quickly. This causes the wheels to bounce up and down and therefore "hop" LCA's are lower control arms. There are two of them, one on either side of the car. The connect the axle to the rear sub frame. This is where the axle pivits agaist the sub frame. Generally they are weak, and after years of abuse the rubber bushings wear out. This causes slop in the system and contributes to wheel hop.
Confused? Buy a chilton's, they have pics and are a good reference.
You will get the hang of it, keep reading!
  • 89 Formula 305 WS6
    SFC's,
    LCA's,
    Air foil
    Flowmaster cat back
    Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
  • 90 Eagle Talon 2.0
    (winter beater)
    Mods? HA! its a rice burner!
Old Mar 14, 2001 | 05:19 PM
voltran's Avatar
Thanks, but what if I wanna lower the front only ? Do I still have to consider those ?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
