Adjustable Panhard Rod - a must ?
Old Mar 15, 2001 | 12:02 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Is it a must to have an adjustable panhard rod when lowering the car ? Im lowering 1.5"
Anything else but new shocks and an alignment that I need to do..?
Thanks for any info!
Ken
Bright red 86 Iroc-Z Choo Choo Customs Convertible
A few free mods
ChevyKen's Camaros
Administrator @ ChevyWorld.net (Now in a BRAND NEW Design)
Old Mar 15, 2001 | 04:55 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
The panhard rod bar will allow you to center the rear end in the car. I have a 84 and the right rear sits in about 3/8 of an inch more than it should. This is important esp since you are lowering the car. You might have clearance problems if one side is not centered. You will have a more rigid connection(less slop side-to-side) esp if you get the adj. spherical rod ends and it will be easier to adjust. If you get the spherical on one end and poly on the other, you might have to remove bolt on one side to adjust. If you have the dual spherical you can just twist the bar and then tighten lock nuts.
Later,
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 at 94.77mph
Old Mar 15, 2001 | 11:56 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Alright, thanks a lot for the info - I'll order me an adjustable panhard rod right away as my lowering springs should be in shortly!!
Thanks again.
Ken
Hotrodboba400
Dec 10, 2019 07:07 PM
Antips16
Oct 30, 2015 06:42 PM
Nervous2
Oct 8, 2015 10:53 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
