sway bar not lining up correct
Old Jun 13, 2010 | 05:13 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
First off I have to tell a little story behide all this.. I hit a curb on the drivers side , busted the Rim, broke the mount on the K member for the A-arm and bent the end link, changed out the K member, the A-arm and different end links and new rim, what i would like to know is why the end link on the on the drivers side don't line up, it's at like a 30 to 45 degree angle, tried a different sway bar and it's the same way. is there anything else that can be bent to make it not line up? i can get pics if need be.
Old Jun 13, 2010 | 07:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: sway bar not lining up correct
did you bend or break the sway bar mount on the frame? is the frame damaged? i assume the passengerside end link lines up right?
pics?
Old Jun 13, 2010 | 07:18 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
I don't see no damage on the frame and yes the passenger side lines up. I'll have to get the pics tomorrow. Like I said I tried a different sway bar and it lines up the same way as the original one does
Old Jun 13, 2010 | 08:01 PM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
on a side note does anyone else's frame look like this, this is the drives side right above the furthest back K member bolt or the A-arm, just hoping my frame is not messed up. btw I'm talking about the V looking spot and the hump looking thing by the lines
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
