KYB GR2 struts and shocks ,,,weird
Old Jun 16, 2010 | 06:34 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i just got a set of front and rear KYB gr2 struts and shocks ...they look fine but ..i noticed that my monroe sensatracs rears shocks are actually bigger and look tougher than the kyb rear shocks...anyone have these and does that make a difference in the quality?..are the kyb much better than my monroes?...not so sure now....thanks
Old Jun 16, 2010 | 07:00 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: KYB GR2 struts and shocks ,,,weird
Big is not always better. Why do you have KYB.s when you think the Monroe's look better???
Old Jun 16, 2010 | 07:04 AM
mooch1's Avatar
Transmission: T5 WC
i changed to KYB because i found the monroes too bouncy ...and heard great things about kyb ...i just was disapointed with the rear kyb's....they look much slimmer than the monroes....does anyone here have the kyb?...how do they handle?....thankyou.
Old Jun 16, 2010 | 12:30 PM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Shock/strut behavior is all about the internal valving.
An external appearance of "strength" does not in itself mean much - you aren't going to break one in anything resembling normal use unless it's defective as it sits in the box or you manage to damage it yourself.
Body diameter usually does suggest something about the diameter of the piston that's inside and maybe something about heat dissipation. But a bigger diameter shock can still be valved "softer" than a smaller diameter one.
Norm
Old Jun 16, 2010 | 02:05 PM
FlamingPhoenix's Avatar
Car: '85 Trans Am WS6
Engine: L69 H.O. 305
I am running the GR-2's front and rear, they handle great. even on rough surfaces the rear stays planted under heavy accel., and no wheel hop.
Old Jun 16, 2010 | 03:48 PM
X-Ravin's Avatar
Car: 91 Camaro RS
Engine: Freshly rebuilt 350 with goodies.
Transmission: 700R4 w/ 2000 Stall
No complaints here on the GR2's. Fairly stiff ride.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
