BRAKE CALIPERS??????
Uneducated guess, but I would have to say no. Basically, the rear calipers are smaller than the front. In addition, they also control the parking brake. I believe that the piston on the rear is a screw-type, while the front is a pressure type. Like I said, just an uneducated guess.
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Front and rear calipers are not interchangable.
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
dbrochard
Sep 19, 2015 08:13 PM
rb85TA
26
Sep 14, 2015 10:29 PM
rudolphschenker
Sep 4, 2015 02:41 AM
