What is it thats leaking?
Old Mar 24, 2001 | 12:24 PM
Hulk0202's Avatar
My power steering is leaking where a black hose connects to the metal junction with the sensor on it. What is the sensor, what is the name of the metal pipe. Do I have to replace the whole thing? It looks like the metal pipe may come apart by the sensor. I'd appreciate any help. Thanks
Old Mar 24, 2001 | 02:06 PM
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
I have no idea what the sensor is for but if the hose is leaking from where the rubber line joins the hard line, you will need to replace the hose. On my 87 Firebird, you can diconnect it from the back of the power steering pump and from the 'T' fitting the sensor is in. As for what the hose is called..... I just call it The hose that goes between the power steering pump and the sensor fitting
Hope that helps
Redbird
Bayou Motorsports
87 Firebird-Daily Driver/Autocrosser
84 Z28-Full bore Autocross car
Delta Region SCCA
#00 C Prepared
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
