Looking for a good torque arm, a few questions.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys I did a search and I'm trying to figure out a good torque arm for me. I'm building my car to be an "all around" car. Not just straight line, not just twisties kind of car. Since I installed the weight jacks ofcourse the wheel hop has come back a touch. What would be a good all around torque arm set up? Adjustablility also is an absolute must. Any recommendations?
Car: '88 Camaro (Gone...)
Re: Looking for a good torque arm, a few questions.
Any of the adjustable, full length crossmember mounted arms should meet what you're looking for. UMI, BMR, Spohn all make them. Just stay away from the short-style torque arms if handling is a priority
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I had the Spohn setup and like it. The only thing I didnt like about it is that the crossmember does not allow for good exhaust clearance.
What kind of rear control arms do you have? I use to have wheel hop, but then I boxed the rear control arms in. The wheel hop went away. I'm still going to get good tubular arms one day, but for $10 for the metal this will work for now.
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
i have a spohn torque arm for sale that fits a th400
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
PA racing has a xmember, driveshaft loop, and adjustable TA for $359...might wanna look into it
http://www.paracing.com/catalog/prod...products_id=96
Thanks for suggesting UMI Performance. We do offer a few different versions of adjustable torque arms. Our mounting bracket works with all of the aftermarket and stock rear ends. And they all feature Energy Suspension bushings. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...m6frm4l3eubdc4
If you have any other questions feel free to ask.
Brad
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
