Which adj Panhard rod is the best?
I am leaning towards Sphon's adj panhard rod, but should I get the one with both poly ends or the poly/spherical combo rod? Car is driven on the street. Thanks
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Polys on both ends make little to know noise at all... they have a little less bind than the stock setup.
Poly/spherical combo is probably the best for the street. has almost no bind, yet is quieter than the dual spherical rod ends
Dual sphericals make teh most noise, but if that is not a concern and only performance is, they are the best...
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven
raven
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i have a LAKEWOOD adjustable panhard rod on my car and i'm very happy with it.you can beat the price $80
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
