IROC Rear Springs......
Old Apr 8, 2001 | 01:34 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I just pulled my '87 IROC rear springs. They were marked with a sticker with a part number 10018091, I think? Are these wimpy or what? Do the GTA's or 1LEs have better rear springs than these? What are the GM part numbers for those springs? Are the Eibach rear springs better for all round performance and can they drop the car an inch or so? Part number? Any thoughts? I drag the car and AutoX occasionally.......
Thanks!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
Old Apr 8, 2001 | 08:25 PM
Eightyninef's Avatar
you posted the GM part #
I'll take the springs if you don't want them.
or I'll trade you for other GM springs that I have.
larryburd@mail.com
Old Apr 8, 2001 | 08:58 PM
Camaro_hunter_d's Avatar
the springs are reletively the same parts through out all the camaros, YES they do have small differances but they are basically the same. If you want to lower your car 1 1/2 inches get springs, they will have increased load ratio. Meaning they will ride harder and give less. Though when you get these I recomend getting lowered shocks/struts.
However I doubt that the Iroc and the 1le are any different.
Old Apr 8, 2001 | 09:28 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I've got the pro-kit in my car its pretty good. For both drag racing and SCCA. My car understeers alot less now with the prokit. THe only ****ty thing is that my car has roll now. Because with the Intrax springs my car was bottomed out all the time. So it was good for drifting. But bad for handling.
Chris
91 RS 305 TBI
Eternal Rev
MORREALE5
Sep 13, 2015 09:16 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
kyleb24
Aug 15, 2015 08:24 AM
BlackBoulder
Aug 11, 2015 11:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
