Wheel & Tires
Car: '87 Camaro Sport Coupe
Engine: 383
Axle/Gears: Ford 9, Detroit Locker, 35 sp, 4.11
Wheel & Tires
What is the widest wheel/tire combo I can put on the back for a drag car? I know 15 x 8.5 Centerlines with 26 x 10.5 Mickeys will fit, but how about 15 x 10 Centerlines with 26 x 11.5 Mickeys?
-Mike
.600 lift solid roller, need I say more?
-Mike
you can fit up to 17 by 11 rims in your third gen but for that you need an adjustable pan hard bar...You can run 17 by 10's I think all the way around I am not sure but I can check my wheel tire book if you want and tell you...when you run these super wide rims you need to change the backspacing as well...I can give all the 17 inch measurements if you want as well....
Engine: 383
Yeah, I know that 17 x 9.5s will fit all the way around. But I'm doing a drag car. I'll use the same backspacing as the Iroc wheels. I am just curious about the fit of different drag slicks in the back. Thanks anyway.
-Mike
-Mike
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
I am curious as to what the back spacing for 17 x11 would be. Is it 6". Do I have to do hamering or modes. What is the biggest tires for this? thanks
I've got 295 50 16's on stock rims on the back of my 92.....
1992 Texas DPS B4C 1LE FE2 5.8/5spd:
Intake and Plenum Ported
Fully Ported Corvette Heads
TPIS Tricks ,No Smog Pump, NOS FI Fuel Pump
K&N's Adj. Fuel Pressure Regulator
Alston SFC's, Energy Supension Hyperflex system
MSD 6AL, SLP 1 3/4" SS Headers, no cats
3.73's with 295/50/16's out back...blew those now 2.73 one legger
My complete back seat
encompases my RF tunes...
Currie 9" on the way with 3.70 gears
Adam
Adam
LT1Formula
Nov 16, 2015 01:13 PM
