Anyone ever heard of cross drilled rotos cracking?
Old Apr 9, 2001 | 10:03 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Looking at upgrading my brakes in the far distant future and I was wondering if anyone has ever heard of cross drilled rotos cracking? I've heard numerous people say that they are prone to shattering but if this is the case then why do people buy them?
Your comments are appreciated
Robert
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old Apr 9, 2001 | 02:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've heard of it. Why do people buy them?
1. Because they look cool.
2. Because if they're good for the track they must be good for the street.
[This message has been edited by Apeiron (edited April 09, 2001).]
Old Apr 9, 2001 | 03:34 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
You could use a slotted rotor...
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Apr 9, 2001 | 04:11 PM
Biochem's Avatar
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by MikeH:
</font>
You should use a GOOD QUALITY rotor... whether it's slotted or cross drilled.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 9, 2001 | 06:12 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
check with the pad manufacturer and see if its even necessary to drill the rotors (unless weigth is your deal). We ran rotors on the TransAm cars (SCCA TransAm series) that weren't even slotted, per the pad manufacturers advice. (PFC pads, alcon rotors).
The fact that a rotor is drilled should have no affect on whether it will crack or not (when they get hot, they get hot).
I'm not sure what the advantages are and how the racing stuff differs from street applications, so I'll shut up now
Clem
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission---FOR SALE---
Looking for a V8, preferably 4 or 5 speed Camaro with NO T-tops (wanna trade?)
[This message has been edited by clemsparks (edited April 09, 2001).]
Old Apr 10, 2001 | 12:36 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I have heard that the process that the holes are made effects the life of a drilled rotor. If the rotor was cast with the hoels in it, it will live longer than if the holes were drilled after the disc was made. Sounds like a valid reason to me. I guess the drilling could make small microscopic cracks in the metal around the hole, and eventually spread.
Old Apr 10, 2001 | 07:47 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Cross drilling/slotting reduces brake swept area. 99 44/100 of all race cars use full face rotors
Old Apr 10, 2001 | 09:26 AM
91RedBigFinZ's Avatar
Look here: http://www.ws6.com/cryo.htm
Doug
'91 Z28 - 50,000 miles. All power options leather. 350 TPI:
K&N; Fastchip; Airfoil; Custom 'Ram-Air'; SLP Headers; Slp Runners; Borla Catback 50% open; Dual factory Cats; Poweraid TB spacer; March underdrive pulleys; Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs; manual fan switch; TB coolant bypass; Pirelli P7000 Z245/50/R16 all season tires; Energy suspention motor mounts; smog pump delete.
S Cobra Radar Detector; Z28 SS Floormats
Old Apr 10, 2001 | 03:04 PM
Jza's Avatar
Jza
I have had Powerstop cross-drilled rotors since March 2000 (a little over a year now) with just under 20,000 miles of occasional spirited driving on them, and they're not cracked or in any way deficient.
Just one experience. Take it how you will.
Old Apr 12, 2001 | 10:41 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Cross-drilling the rotors was mainly to give the gases generated by heating the pads (stepping on the brake....) someplace to go. the problem you run into is on the inside of the swept area (between the disc faces) the drilling process leaves burrs. This is a good place for cracks to start. Most pads manufactured today use compounds that significantly reduce out-gassing of the pads, so cross-drilling is not really necessary.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
PurelyPMD
May 5, 2016 04:57 PM
codeysabatini
Sep 20, 2015 11:36 AM
Night rider327
Sep 16, 2015 02:20 AM
84 TA NV
Sep 6, 2015 08:02 PM
