how do you torque the struts?
Old Apr 12, 2001 | 06:46 PM
matthew's Avatar
I finally got around to putting on my struts and I can't get them torqued because the rods keep spinning. there is a place to put an allen wrech in the top, but then I wouldn't be able to get the socket on. Its a lock nut so I don't think it will come off. would it be ok if I got it really tight with a wrench and called it good? My chiltons manual says to torque to 44 ft-lbs, is hand tight around there?
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Old Apr 12, 2001 | 06:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Use a box wrench instead of a socket, or an air gun.
ICON Motorsports
Old Apr 12, 2001 | 06:52 PM
matthew's Avatar
I've been using a box wrench. But they don't tell you how many ft-lbs your pulling on them.
Old Apr 12, 2001 | 08:49 PM
ede's Avatar
ede
tighter than hell works out real good for me, if you can get them tighter than hell try real damn tight
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 13, 2001 | 12:34 PM
CamaroMike's Avatar
Zip those fu(kers on with an impact an leave it alone. Worked for me.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Recently Ported Heads, Installed Larger Race-Flo Valves and RPM Air Gap Intake (No new times)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Apr 14, 2001 | 11:20 PM
matthew's Avatar
well I solved my own problem. I used those crow feet sockets with the open ends and put that on my torque wrench. Worked great!
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
