Spohn or UMI 700R4/T5 Cross Members
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Installation, vibration, mount type, drill and tapping, etc. Any experience, good or bad, would be helpful.
JamesC
JamesC
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spohn or UMI 700R4/T5 Cross Members
the crossmember even worked flawlessly with my tko600 with the help of a couple homemade spacers.
Didnt get a vibe from that, but i did get one with the energy suspension poly mount with the preload plate that comes with the mount, not sure why its there. I replaced it with a prothane one a couple years ago and its been great. Could probably get away with rubber still, if you pickup any bad vibes.
Not sure if one hangs lower than the other.
I'm running a poly mount currently with a secondary cross member. If the Spohn/UMI have the same height, I should be good--I hope.
Car: 86 Trans Am
i have the umi one, but with the torque arm attached. Smooth install, fit like a glove. I tapped the extra hole in the subframe for the extra 2 bolts, think it 10mm1.5. Didnt have to drill the extra nut, it was already the right size IIRC.
luvofjah
Sep 26, 2015 08:28 PM
