Front Suspension Terminology
Old Apr 18, 2001 | 10:04 AM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
I am new to the suspension thing and I am getting confused about some things. Are there are lower control arms on the front and the rear? What is the triangle shaped piece on the front suspension that has what I think is a ball joint and two bushings that mount it to the car. Are there any pictures posted anywhere that I could use for reference? THANKS !!
1986 IROC LG4 "Bone Stock" (for now)
Old Apr 18, 2001 | 11:19 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
<font face="Verdana, Arial" size="2">Originally posted by wiggy'sIROC:
What is the triangle shaped piece on the front suspension that has what I think is a ball joint and two bushings that mount it to the car</font>
That would be the lower control arm..., and yes, there are LCA's in the front and the rear...
KAM
Old Apr 18, 2001 | 01:39 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Heheheh, technically, the rear pieces are lower trailing arms, but nearly everyone calls them lower control arms. Trailing (and leading for Jeep owners) arms run front to back, while control arms are side to middle (ie: perpindicular to trailing arms). Thunderstick is right that what you saw up front is the lower control arm.
Greg Westphal
'87 IROC 305TPI/A4
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
cam-mike
Aug 24, 2015 07:23 AM
