Panhard Rod Adjustment???
Car: 91 Z28
Engine: 5.7L
How can you tell when the Panhard Rod is adjusted to the proper length?
Thanks Jay
1991 5.7L Z28
14.456 @ 92.78 MPH
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
The "eyeball" way is to just look at your rear tires from the back of the car. If your ground effects cover the same tread portion on each side, you're pretty damn close to good. The other way is to take a tape measure, and measure the distance from the inner sidewall of your tires to the side of the wheel well.
Car: Take
Engine: Your
Transmission: Pick
The best way I have seen is to:
[list=1][*] Take two pieces of string, and tie a small weight on the end (just a few ounces)[*] Tie each string to each rear wheelwell. It must be in the same spot for both sides.[*] Measure the distance from the string to the sidewall of the tire. Adjust the Panhard bar untill both measurements are the same (from side to side)
[/list=a]
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[/list=a]
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Hotrodboba400
Dec 10, 2019 07:07 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
