96 trans am rear end
Car: 1992 formula WS6
Engine: none
I can get a 96 trans am rear end with 2.73 gears in it for 300 dollars. What else do i need to get to put this rear end in my 92 formula. I have drums now. But with that rear end i will have disc brake in the rear to. So do i need to get.
please help me ASAP
please help me ASAP
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Park brake cables, master cylinder and pressure differential switch for disk brakes. You'll also need proper offset rims since the 96 is 2 inches wider on each side.
There's nothing special about the rear end itself when compared to yours. They both have 28 spline axles. Why not just buy the disk brake parts and install them on your diff?
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
