How do I know what brakes I have?
Old Apr 22, 2001 | 11:42 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
With all this conversation about brakes lately, I have a question. I've looked through the archives and can't seem to find the answer.
I have a 90 Formula 350. How do I know what brakes I have on the car?
When I go to the parts store and give all my info (engine size, package, 4whl disk), there are 2 things available for the front. One says "w/perf package" and the other says "w/o perf package".
I assume the "perf package" refers to 1LE brakes, but how do I know? Are the pad shapes very different?
Oh, BTW, yes, I am too lazy to pull a wheel and a caliper and grab the pads and take them in to compare. I need to do all 4 corners for brakes (and struts/shocks, and springs, and bushings...), and I want to get my ducks in a row before taking anything apart.
Anyway, can I tell by option codes? Anything else easy or general?
Thanks for helping another FNG!! (f'ing new guy)
Old Apr 22, 2001 | 11:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Unless you have 1LE, you don't have the "performance package". None of the regular brake parts is even remotely similar to the 1LE parts.
Old Apr 23, 2001 | 07:20 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Take a magnet and see if it sticks to the front calipers. If it does, then you have the regular brakes. If it doesn't and the calipers have fins on them and look like they're aluminum, then you have the 1LE brakes. Yes, the pads for the 1LE brakes are quite a bit different from the regular brake pads. 1LE is the option code, so you can find out if you have that by looking at your options sticker and seeing if it's listed. Sometimes, perf. package refers to having 4-wheel disc brakes as opposed to having drum brakes in back, but you'll have to check with the shop to see if they have a separate definition for that...
Greg Westphal
'87 IROC 305TPI/A4
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
