Cheapest ($ wise) lowering springs
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
I want to lower my car at least 2 inches. what is the cheapest place i can get some. i found some good ones for $260 but is there any place cheaper. Thanks in advance...
oh. and whats the max you can lower our cars without replacing the A-Arms. Thanks
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns, MSD 6A Ignition Box, MSD Conductor Spark Plug Wires .
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000.
For Pictures go to
http://members.theglobe.com/RED82TA57L/mycar/
A cool Trans Am site with Message Boards http://www.transamgta.com
RED82TA5.7L
For Pictures go to
I have seen 1 1/2 inchers for 189...out of summit..Intrax I think is the manufacturer...I do not know the quality though I am interested in some and would like to know more about them...Personally I would only lower max 1 1/2 inches or else you run into big tire clearance probs. And 1 1/2 inches is a good stance with even 16's...better with 17's...
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
http://www.bmrfabrication.com/
they have a full set of 1.5 springs for $99.99
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/
Engine: LT1/350 TPI
WOW. $99 for a full set. i think ill get those. i went to the site and they look good.
RED82TA5.7L
For Pictures go to
RED82TA5.7L
For Pictures go to
I bought my Intrax for $100 off Ebay! Brand new, never installed. The company was auctioning off a lot of them for different cars. Springs and Things was the company you might want to look them up.
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil,MSD Wires, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added.
Stereo has 2 Clairion Pro Audio dash plates, 2 Sony 6X9s, 2 Kicker 12's in a custom Carpeted box with a custom amp rack Holding 3 MTX 280 Amps, and a MTX electronic Crossover all wired with EFX cable.
Asking $4200 with all extra Parts that are needed to fix most apearance flaws. ie Complete hatch and wing from a 91 GTA
http://geocities.com/feltsb/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/2 ton 350, one of those NASCAR F150's
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Kills:
Car: 1983 Z28
Transmission: WCT5
those BMR ones in the link above are Jamex springs if anyone's interested. I emailed them, and got a reply in a matter of hours. If I can save up the cash fast enough, I just might order a set myself.
Clem
Clem
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I bought the Jamex springs from BMR Fabrication. Made the car look and handle better.
Here are some pics.
The top 3 pics are after I lowered the car.
http://www.leannrimes.cz28.com/exterior.htm
This shows a comparison of lowered and stock.
http://www.leannrimes.cz28.com/springs.htm
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Here are some pics.
Zepher
WS6 Trans Am
JC whitney sells some clamps that you can use to clamp one coil of each spring completely compressed. don't know how much it costs but I'm sure it's cheaper then new springs and a lot easier to install to.
you dont need the spring compressor when installing the lowering springs.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Brandon
New project-89 IROC
Engine: LT1/350 TPI
thanks for the info guys. i bought the ones from BMR. they should be here on Monday. i can wait to see and feel the difference.
RED82TA5.7L
For Pictures go to
RED82TA5.7L
For Pictures go to
hey i just put the Jamex springs on the other day and WOW!
the car handles much better now. i went ahead and had the allignment checked and it was a little off so they fixed it. the fronts were'nt that bad and the rears takes all of 20 minutes to put in.
Brandon
New project-89 IROC-Jamex Springs...and thats just about it till summer!
the car handles much better now. i went ahead and had the allignment checked and it was a little off so they fixed it. the fronts were'nt that bad and the rears takes all of 20 minutes to put in.------------------
Brandon
