Removing Front Springs
Old Apr 26, 2001 | 02:50 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
On one of the car TV shows I saw them put a jack under the control arm,undo the spindle and lower the jack to take the coil spring out. Can we do that on our cars? Is this safe? These guys on these shows can be full of **** sometimes and I was wandering if this was one of those times.
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old Apr 26, 2001 | 05:07 PM
nestz28's Avatar
I've heard of people doing it that way but it seems too dangerous to me, there's so much pressure on the jack that the control arm might slide off and the spring may come flying out. The way I did it when I took my springs out was to disconnect the brake line and the top of the strut and lower the whole assembly including the control arm down until it is as low as you can get it (you have to have the car raised pretty high to do this or the control arm will not go down far enough) when it is down the spring is almost decompressed and then you can just knock it out with light taps from a hammer. I also tied a rope from the spring to one side of the control arm to keep it from flying out while I lowered the control arm.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
3rdgenparts
Aug 8, 2015 07:09 PM
