Bushings
Old Apr 26, 2001 | 01:23 PM
robbob's Avatar
Bushings
How hard is it to replace the the front end bushings,especially the control arms.Does the car have to be off the ground,basic tools etc?
Old Apr 26, 2001 | 01:48 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
In order to replace your front end control arm bushings, you have to remove the control arm, and that means you need a spring compressor unless you choose to do it with a jack from under the control arm. Once you get them off, the bushings have to be pressed out, or in most cases beaten out (like with a chisel) but the good news is that you can press the new ones right back in. You'll need some basic tools as in ratchet and metric sockets/wrenches...
KAM
Old Apr 26, 2001 | 08:03 PM
robbob's Avatar
Thanks!
I guess I'll let the garage do it,I would hate to f**k up my front end.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
camaro1185
Oct 26, 2015 06:51 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
