uneven rear
Old Apr 27, 2001 | 09:11 AM
snoozeyaloose85's Avatar
uneven rear
Why does my rearend stick out a little more on the driver's side. Everything is tight and it is all stock. Do I need an adjustable panhard rod could the stock one be messed up. 85 305 tpi ta
Old Apr 27, 2001 | 07:14 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
is your car lowered?
Old Apr 27, 2001 | 08:03 PM
No it's all stock
Old Apr 27, 2001 | 09:22 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
It is most likely an optical alution. or perhaps the car got curbed at one time and bent the control arms.
Old Apr 28, 2001 | 11:17 PM
82camaro's Avatar
Car: 82 camaro SC
Most third-gens aren't centered perfect in the rear(doing alignments I never saw one), unless they have an adjustable panhard bar. How far off is it. As long as both rear wheels are pointing straight down the road, it isn't a serious problem. What are you comparing it to on each side. It could be the fender is a little bit off.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 30, 2001 | 08:58 PM
812MANY's Avatar
I dropped strings when I installed my CE torque arm and I found that the rear was moved 3/16" to the driver's side at stock ride height (stock suspension).
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
