I got some ?'s about lowering my car.
Old May 2, 2001 | 08:21 PM
SLVR28's Avatar
I like how my cars suspension is but I would really like to change how it sits. I was wondering what is the best way to do it or how much I should change it. I was going to raise the back 1" and lower the front 1" but Im not sure if thats a good I dea so thats why I ask you guys, the pro's. Well If you know any info that would help I would like to hear it. Thanks
I have a 1984 Z28 Camaro 305 H.O. It also has a 5-speed. It had a 3.73 posi rear-end but that had to be taken out due to some breackage of a couple of teeth. so I am currently looking for a *posi unit and 4.10 gears*.
Projects for the future are: I have a 4 gen SS hood scoop to put on my car and when I get that complete I plan On getting a K&N open element and Xtreme filter lid.
By the way My little stock 305 runs 14.5 @ 96mph on the 1/4 mile. I think thats pretty good for a stock 305.
Old May 2, 2001 | 10:31 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
I have a 84Z28 HO and just recently changed to the Eibach pro-kit springs and tokico shocks/struts. My car had the reverse tilt goin'. Big gap over front whls and small gap in rear. When I put in the new springs they lowered the front 1" and raised the back by .5". It now has the proper rake. Only thing I can figure is the rear springs were shot. I have taken off the a/c and smog pump so that helped lighten the front end.
Hope this helps,
email me direct if you have any questions/comments because I don't always have time to check the board.
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 at 94.77mph
Recent additions: Del-A-lum front control arm bushings, Moog ball-joints, Energy suspension front sway bar end links, Moog rear sway bar end links, Eibach pro-kit springs, tokico shocks/struts. Need relocation brackets and control arms.
Old May 2, 2001 | 10:47 PM
ScreaminDeamin85Z's Avatar
check this out.
http://web.camaross.com/bb/Forum6/HTML/033837.html
these will lower your car 1.5" on all 4 corners. i have these on mu car and must say that i like the way it sits and the handling improvements.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old May 3, 2001 | 11:43 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I had the same reverse rake thing goin' on as Craig84Z. I put new shocks all the way around and that fixed it. I'm going to lower it with Intrax Springs. I just wish I would've gotten Koni adjustable shocks. You ain't gotta take 'em off to adjust 'em. The adjuster is on the shock tower.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
87iroctheo
Dec 4, 2016 11:47 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
