Susupension and brake questions......
Old May 2, 2001 | 01:11 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
1. With the exception of the 1LE package, are the front disc brake assemblies on 85 and newer F-bodies pretty comparable across the board (RS, Z28, WS6, IROC, etc...)? If not, can somone who knows these systems in and out explain the differences in detail, pros and cons, differences and improvements between both years and different models.
2. Same question as above with respect to the rear disc brake assemblies that came with these cars. I know there are differences and shortcomings, anyone care to explain in detail......
3. Is there really a noticeable difference and is it worth the time to upgrade to a quick-ratio steering box on a car that does not have one? Anyone who has done this swap, your input would be appreciated...
4. On a car with an open rear and drum brakes, would it be much smarter to just install a 4th gen rear with posi and discs, or is a 7.625 rear, 3.23 posi and discs not a bad assembly? Either one would be a good upgrade, but I am thinking it would just be smarter to go with the newer assembly, I just need someone to affirm this. The car in question already has the latter rear available to it.
5. When switching from drums to discs, how important is it to switch the master cylinder and prop. valve? I have seen many swap rears with or without changing these items. Also, with respect to a 4thgen rear, is changing these items even more important?
Thanks in advance for your input.
Old May 3, 2001 | 10:40 AM
89ragtop's Avatar
Not all at once now.
Old May 3, 2001 | 08:15 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
#1 The stock brakes suck.#2Same as #1 #3 An IROC steering box is preferred(quick ratio and stiffer).#4The stock rear is fine for non supercharged use.#5Use the stock prop valve first. 9if you have undesireable brake reactions. Then change it.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
