New alignment - Caster and Camber still out
Old Jul 22, 2010 | 04:50 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
So Finished rebuilding most of the front-end and took it for an alignment. They were able to get the toe right however the caster and camber are still off. The shop mentioned it was already fully adjusted and nothing could be done. Could someone let me know if the below specs will do much harm to the tires? Is there something that could be done to fix this? Otherwise it handles and drives fine.
___________Left_______________Right
Camber____-0.5________________-0.4
Caster_____ 4.5________________ 3.9
Old Jul 22, 2010 | 05:00 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Re: New alignment - Caster and Camber still out
Theres not alot of adjustment factory. but a nice set of caster camber adjustable plates would help(upper strut bearing plate)They give more adjustment and allow for better strut travel giving you more front end control.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
89 formula TPI
Sep 20, 2015 10:54 AM
