Steering noise???
Old May 8, 2001 | 11:15 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Steering noise???
When turning the wheel back and forth at low speeds i hear a popping sound? Has anyone ever had this problem before, and if so how did you fix it. All the tie rods are new and the ball joints appear okay. ???????????
Old May 8, 2001 | 07:12 PM
coach's Avatar
Do you also hear a rattling when going over bumps (kind of like someone shaking a handful of coins). If that is the case, I'd check the sway-bar end links. If they're stock, they're rubber. I also noticed the popping sound with my car. I haven't heard the noise, since I replaced the end links with polyurethane ones. I replaced them because they were brittle and rubber pieces had broken off.
Something you may want to check.
Old May 9, 2001 | 11:57 PM
CrazyRob75's Avatar
Check your frame rail behind your steering box to see if it's cracked. It's a common problem, I had it on mine. A little MIG and a wonderbar, the car now drives like new. No more popping either!
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
