Sway Bars
Old May 10, 2001 | 12:14 AM
pookey's Avatar
Sway Bars
May sound stupid but do sway bars (front and rear) go bad or just the bushings? Also whats the difference between a stock sway bar and say another companies.
88 White Formula 305 TBI With Abosulty Nothing Done To It!
Old May 10, 2001 | 02:15 AM
Jza's Avatar
Jza
They don't "go bad", but they can suffer from road damage if you run up a large enough curb or hit something tall enough. Or the bolts can work loose. But mostly the rubber bushings just break down from age and oil exposure. That's why most ppl here replace with polyurethane pieces; they're impervious to oil and other automotive fluids.
Aftermarket bars could be thicker or solid or made from stronger materials. Also some may incorporate a slightly different design adding one advantage or another (like the ones that use spherical rod ends instead of end-links).
Old May 10, 2001 | 02:47 AM
pookey's Avatar
So basically its not the bar but the bushings. And the proprolene (excuse the spelling) ones your talking about are the best. I also assume this will tighten the car up during high speeds and turns.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
