Shock install ?'s
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Shock install ?'s
Do the rear trim panels need to be removed to install new shocks? I have an amp rack sitting behind the seat for my stereo system and the shop guy said I would have to remove it before he would install the shocks. The car is a 85 Trans am. Any info on how to get to the shocks would be great.
85 305tpi Trans am
flowmaster exaust
K&N air filter, 4:11 rear gears
yes you will have to remove your amp rack, I know, its sucks, I had to do it too. The upper shock mount is right behing your back seat. you have to move the back seat forward. Then somehow find a way to pull the carpet back. (note: this is the hardest part of changing shocks) After that, take the nut loose. Then move under your car and remove the lower bolt. take shock out, and then put the new one in. and reverse the procedure. Getting a Chiltons manual will really help, as they have pictures and torque specs.
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Now KYB equipped!!
Look down at the hump once you folded the seat down. See how it's actually a flap? Just lift that whole thing up and there's the upper shock mounts (under two foam covers).
If the rack is flush with the forward wall of the floorpan, you may even be able to get away with not removing the rack at all.
Car: 85&95 Trans am
I've tried pulling the carpet back ,but it's glued down to the panels. Do I need to remove the bolt that the seats latch to so I can get to the shocks?
85 305tpi Trans am
flowmaster exaust
85 305tpi Trans am
flowmaster exaust
Car: 82 camaro SC
Not the carpet on the panels, the carpet that is laying flat needs to come up. Under the carpet will be a piece of foam, under that is the top of the shock.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
