Popping inside of steering column.
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
My steering column is loose, not the tilt part that everybody is complaining about (I fixed that already). When I turn the wheel, it pops first, then I can turn the wheels. At first I thought it was the rag joint, but I took out the shaft between the steering box and the column, put a screwdriver through the hole at the end of the column and rested it against the valve cover. When I apply pressure on the wheel I hear the pop, then I turn the wheel the other way so the screwdriver is against the master cylinder, and it pops again.
So it has to be something in the column itself, right? Any ideas what it might be?
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.73 @ 95... traction still a problem
Randomtask2
Sep 10, 2015 08:37 AM
punkmaster98
Sep 8, 2015 09:45 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
