1st & 2nd Design E-Brake cables
Old May 12, 2001 | 09:55 AM
haddocrf's Avatar
I am doing a rear end swap on a 92 Firebird from a 10 bolt with 2:73 and drum brakes to a 9 bolt with 3:27 and disk brakes with the performance package. I went to the local Pontiac dealer to order the left and right E-Brake cables and they show two for my car. A 1st design, which is about 1.5 inches longer then the 2nd design. The only thing they told me was that I had to measure the old ones to get the right new ones. I don't have any to measure. Does anybody know any other difference in the cables? Is the 2nd design better, or did they redesign it shorter to stop rubbing somewhere? I hate to order the wrong one, once I order it, it's mine.
Old May 14, 2001 | 08:22 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
I did the same thing with the GTA. The E-brake cables are different depending what type of rear disk brakes that you got, either the older GM style 10" rotors from 82-88 or the PBR aluminum caliper 11" rotors from 89-92. The cables are not interchangeable.
Order the cables for the type of brakes you got. You can also order them from a NAPA store for about $15 each which is probably a lot less than the dealer.
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
