Check out the Spohn Performance Board for 1LE brake stuff.
Old May 14, 2001 | 07:37 PM
MikeDwhoROCZImports's Avatar
He might be building some parts for cheaper than GM but needs to know the demand.
Old May 15, 2001 | 05:03 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Steve Spohn, I will try to find out the current availability of these brackets,etc., from GM today. I believe that their is quite a large market for the 1LE front brake upgrade. Especially if the user can save some money by modifying his own spindles.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
