Installing ZR1 cast alluminum rims on 92' camaro!little help!!!
I have a 92' camaro RS with drum brakes out back. Now i plan on getting ZR1 rims(17x9) rims on all 4. Im gonna put 275/40/17 goodyear eagles out back and 245/40/17 in the front. NOw for my question do i need an Adapters or Spacers for all 4 corners. Basically what do i need to fit the ZR1 rims on the stock chassis of a camaro
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
depends. are you getting actual ZR1 rims from a Corvette, or are you getting replicas like the ones in Summit. the replicas can be made in the correct offset so no spacers are needed, in which case you'd need a 5 inch backspacing. the corvette rims would need spacers, and skulte can get you the spacers.
those rims are pretty cheap from SLP now. yes you need 4 spacers or 2 spacers and a 4thgen rear.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
