rear end question
rear end question
I just picked up a posi disc rear out of an 86 tran-am. It is my understanding that all third-gens came with a 10 bolt rear. Is that 10 bolts that bolt the cover on? The rear-end I got has only 9. I'm confused. Please help.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You have a Borg Warner 9 bolt. It's stronger than a 10 bolt but parts are expensive and hard to find if you break anything. Nothing internal is exchangable with a 10 bolt. If it has a high gear. ie. 2.77 then you'll have to find a 9 bolt series 3 carrier to go to 3.27, 3.42, 3.70 gears.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
