Cant Lock up Brakes
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Cant Lock up Brakes
With both feet on the pedal ! The car has 4 wheel disk with fresh rubber, tires grip like mad and no pedal fade. Is this normal?
Don
Don
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Probably blocked rubber breakhoses,due to age,happened to me as well!
Just renew them,and use DOT 3 brake fluid,NO DOT4!
umm I cant lock mine either unless I am on a lose suface..Gravel/dirt/water ect... I think this is better than the brakes locking up... Consider it free anti lock brakes. Remember that if your brakes lock you go into a slide and loose control. Now if you just want to do doughnuts and small "controlled" slides yank the E-Brake cable and hold on
Night rider327
Sep 2, 2015 04:17 AM
