82-92 camaro bolt in roll cage?
Old Nov 6, 2013 | 06:50 PM
  #51
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Re: 82-92 camaro bolt in roll cage?
Originally Posted by BlutUndSieg
Not sure about the quality or ease but I stumbled across this somewhere in the depths of the internet. Its a ten point for third gens and you can choose chromoly, dom, or ews for materials. I have been entertaining the same idea for my third gen.
http://www.swracecars.com/store/1982...4=11-1513.aspx
Those guys seem to have great prices on roll cages. An autopower cage is about $950. I got mine used for $200
Old Nov 24, 2013 | 07:08 PM
  #52
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
they do make a nice set of door bars.to fit your stock doors with armrest.
so ya don't have to look like a hack job.
don't like there swing out set up for the door bars. I had to do some looking to get the style I wanted.was about $70 a side to get the bar latch I wanted.
and then the Quick pin I wanted was another $15 ea. it's all about the little things that make it stand out.
Old Dec 14, 2013 | 01:36 PM
  #53
t-top89's Avatar
I have had both weld in and bolt in bars. I have tested many welds and many bolts in my inspection dept. One thing I know for sure is that the bolts are more consistent. If you dont have an AWS certified welder (with current certs) welding in the cage, then you truly never know what your getting. With a bolt, you know almost exactly what your getting everytime.
Old Dec 14, 2013 | 01:56 PM
  #54
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Just be sure the cage you choose, and the install will pass Tech for whatever racing you intend to do.
Old Nov 24, 2016 | 03:24 PM
  #55
brick12's Avatar
Car: 1986 camaro Iroc
I am looking for advice simular to what's been going on but my thoughts are a little different. I have a 91 that I am building to get back into autocross I think what I'm getting out of all these comments is a weld in is safer and better. I do DD my car(sunny day only) and I am not a fan of the thought of unbolting but i guess what I'm getting at it that I would like to get a roll bar and I plan to change out the seatbelts to a 4 or 5 point harness and I just need to know if ordering one is a better option than having a custom one made
Old Nov 24, 2016 | 09:36 PM
  #56
http://www.autopowerindustries.com/R...992?syear=1992
this s a start for some good fitting kits
Old Nov 25, 2016 | 02:34 PM
  #57
project89's Avatar
c.e. engineering weld in cage with a set of door bar swingouts
the mild steel kit is cheap but heavy , the chromoly kit is much lighter and about 250$ more, but it needs to be tig welded in to be legal
u can use the door bar swingouts with either kit
i think the swingouts cost about 70$ per side
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
89lsc
Aug 14, 2015 04:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
