FREAKIN BRAKES!!!
FREAKIN BRAKES!!!
How the hell do you do this??????
Ok, I'm trying to change my front pads and I took the caliper off but I can't back the piston off so the new pads will fit over the disk, what am I missing here??????? Is the piston froze??? Do I need a new caliper??
www.TransAmGTA.com THE 3rdgen Firebird Site!
1992 GTA (226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, My Window Sticker, LB9, 700R4 4-Speed, T-Tops, Grey Leather, every available option except G92, J65 and U1A.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, K&N Air Filter, and Mobil 1.
Future Mods/Upgrades: None but a complete restoration.
Best Track Time: 14.6sec@96.6mph
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
[This message has been edited by 92GTA (edited May 24, 2001).]
Take the top off the brake reservoir and siphon some of the fluid out with a turkey baster (syringe with sucky bulb), then compress the caliper piston using the old pad and a large C-clamp. It should slide right back into the bore, allowing you to put the new pads on!
Hope this helps!
Hope this helps!
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Dude, you can get a special caliper piston tool for like $6 from any auto store. The part about the reservoir cap removal is right on.
Go out and buy one of those nifty Chilton books
Chaotic Firehawk can be found wondering NEThirdgen.org and 3rdgen.org
"A musclecar, by definition, is a powerful and sporty vehicle that must be able to spin its tires at will. The Firebird Trans Am is capable of laying down twin black streaks of rubber several hundred feet long. We wanted to be sure it could, so we did it a half dozen times in the name of automotive science."-MotorTrend
hey guys i did all of the above. and my brake pedal is SOO Mushy. i even changed rotors and calipers, put decent pads on, bled the brakes and put a new flex hose on one side. and they are now worse than when i bought the car, they take forever to grab, and the pedal is almost to the floor. what should i do.
i know this isnt correct since my friends 92Z as soon as you touch his brakes, they start to grab but mine, they just linger till you really slam it down. i hate it, any ideas,
if it doesnt get any better, i am just gonna go and this winter buy the BAER track system with 6 piston calipers, and aluminum rotors. i hate this.
also thought of the 1LE system, but parts are so scarce now. oh i will see what you guys have to say!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
Jarrad
TH-700R4
dbrochard
Sep 19, 2015 08:13 PM
