Cheap Suspension Upgrade
Old May 24, 2001 | 04:54 PM
colinfinkle's Avatar
I would like to swap out the suspension and/or the steering system to gain the best handling. What car should I be looking for? I have found a 85 Berlinetta, would that do? When I do I am going to put lowering springs and shocks. Should I worry about bumpsteer for an inch of drop?
Thanx,
Colin Finkle
87 Sport Coupe Camaro, 5.0 L V8
Old May 24, 2001 | 07:57 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Hey,
you're probably not gonna like this but...Start with a complete suspension and steering rebuild. An '85 is gonna be worn out (most likely) and anything else you throw at it will just accentuate the sloppy old parts. Make sure you get it to a good baseline before throwing part/money at it.
that's my $.02
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old May 25, 2001 | 05:47 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I'd have to agree with Clem.
I think that bringing an older car back its original spec will provide more noticable gains than swapping in used parts from another car.
There are things you can do though. Like if you change out the steering box you can get a faster ratio than stock even without having to chase down one of the IROC quick ratio boxes.
Begin with a good base and then make one change at a time so you'll whether it worked or not.
Old May 27, 2001 | 01:30 AM
Chaotic Firehawk's Avatar
WS6 Springs and sway bars are a good improvement.
J-money
Jan 4, 2019 09:45 AM
Fronzizzle
Feb 9, 2017 09:31 AM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
