Baer brakes installed...no difference
Old May 25, 2001 | 12:05 AM
HybridZ's Avatar
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
Well its been over a month now since I installed my Baer brakes Track system with zinc washed crossed drilled and slotted rotors. I performed the break-in procedures but I dont feel a difference in the stopping power and my brake pedal still feels kinda spongy. The stopping feels the same as if I didnt change anything at all.
What could be wrong. I blead the brakes from the farthest to the closest, the brake fluid is at its required level, and Ive doubled checked everything. Any suggestions would be helpful.
Thanks in advanced guys.
SS 17x9.5 wheels,
HOTCHKIS 1"drop springs,
HOTCHKIS tower brace,
Bilstein struts and shocks,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
SLP intake runner (plennum not ported yet, soon)
High flow cats,
SPOHN panhard bar, lower control arms, and subframe connectors,
Baer front track system,
3" Flowmaster Exhaust System,
2100 Stall High Performance Torque Converter,
300 watt sound system,
and soon to come...ZZ4 crate motor...hopefully.
Old May 25, 2001 | 02:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Did the kit have a new master cylinder, and if so, did you bench bleed it before putting it on? You could still have some air hiding in there somewhere.
Old May 25, 2001 | 07:15 AM
Metalifann's Avatar
sounds like a master cylinder.
Old May 26, 2001 | 03:43 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
What brakes did the car originally come with?
What kind of a car is it? Does it have the stock master cylinder?
Old May 26, 2001 | 10:06 AM
Stuart Moss's Avatar
Since you stated that they feel "kinda spongey", I would second the thought that they have not been bled properly and that there is some air somewhere in the line causing the lack of firmness in the brake pedal.
If you got them from Baer, I would presume that you have the correct components (master cylinder, proportioning valve, etc.). Along the same lines, I would suggest that you give techincal support at Baer a call since you got a new system from them. I would imagine that they have experience with all types of problems from their customers.
Old May 28, 2001 | 06:16 PM
HybridZ's Avatar
Well first of all its a 91 z28 with the L98 package, not the 1LE. And no the Baer brakes package did not come with a master cylinder. I will try bleeding the brakes again and then go from there. Thanks for the input guys.
SS 17x9.5 wheels,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
High flow cats,
Old May 28, 2001 | 08:43 PM
ANDYZ28's Avatar
Car: 1982 Z-28
So you have aluminum caliper disc rear brakes? If so I can't understand the "lack" of inprovement.
My 1LE setup will put you through the windshield. No kidding. Even after smoke rolls from the brakes. They stop even better.
Keep us informed. This is very interesting.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
