New to suspension work, SFC's, driveshaft loop, crossmember, lift bars, all I need?
Old May 29, 2001 | 10:11 PM
Taylor92RS's Avatar
These all come with the South Side Machine package. Will this give me good suspension improvements? What does a strut tower brace and a panhard rod do?
Old May 30, 2001 | 06:49 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
The STB helps to keep the shock towers in place under hard cornering. There is flex of almost 1 - 2 inches, depending on the conditions.
The Panhard rod helps to keep the rear in place under the same conditions (hard cornering)
Both are necessary for road racing or auto X'n, for sure. Not so much for drag racing, though. The SFC's and driveshaft loop are are definitly needed, though, as well as with road racing.
I'm adding the weld-in SFC's and a 4 pt rollbar to tie everything in and tighten it up.
A black '90 Pontiac Formula with a 305 ci TPI V8, 5 spd, WS6 suspension, 140 mph speedo, 10 disc CD changer & T-tops. Several mods currently on order, with more to follow.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
