9-bolt backing plate question
Old May 29, 2001 | 11:59 PM
Metalifann's Avatar
I am going to convert my 9-bolt borg warner rear out of an 86 trans-am to the newer 12" rotors. I was planning on buying the backing plates from David Auster .
I emailed gmpartsdirect.com and they said that the part# mattered on whether I had a 7.75" or 7.625" ring gear. Why would this matter? How do I tell which one I have? Where do I measure from? Please help me. I want to make sure that I get the correct backing plates.
Old May 30, 2001 | 06:25 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
A 9-bolt is a 7.75". It's the size of the ring gear.
The newer 10 bolts (somewhere around '90(????)) are 7.625". Earlier ones were 7.5".
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old May 31, 2001 | 12:02 PM
Car: '89 Formula
Engine: 355 TPI
Right bracket for '89 9 bolt with PBR aluminum calipers is PN 10136851. That's available. Poughkeepsie Chevrolet here in NY has 2 on the shelf. $44.
Left rear is pn 10136852... supposedly discontinued. I'm looking for one myself right now.
Old May 31, 2001 | 02:08 PM
Tad's Avatar
Tad
Caliper carrier #10112652 need 2 $23.22 ea.
Backing Plate #10136853 L/H $10.73.
Backing Plate #10136854 R/H $10.73.
From gmpartsdirect.
[This message has been edited by Tad (edited May 31, 2001).]
Old May 31, 2001 | 02:27 PM
Car: '89 Formula
Engine: 355 TPI
<font face="Verdana, Arial" size="2">Caliper carrier #10112652 need 2 $23.22 ea.
From gmpartsdirect.</font>
Is that for 9 bolt stuff or 10 bolt???? I was just looking at the stuff at lunchtime.
'89 9-bolts were the only ones that came with PBR calipers. Earlier 9 and 10 bolts had the crappy GM rear disks. '90 and up 10 bolts had PBR's also.
Personally, I swapped the 10 bolt in my GTA for an '87 9 bolt and am trying to ditch the old GM style rear disks that came with it.
Old May 31, 2001 | 05:38 PM
Tad's Avatar
Tad
It's the stuff for the PBR calipers. They will bolt on 10 bolt. I put them on 87 10 bolt out of T/A. They sould bolt up to a 9bolt but not sure.
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
