Clunk when braking from passenger front side
Old Jun 1, 2001 | 08:51 AM
Steve89GTA's Avatar
When I get on the brakes a little harder than usual I get a clunk from the passenger front side that I can feel in the pedal. My buddy in the passenger seat said he could also feel it below him. What could this be? I've never changed ball joints on the car and it has 180,000km on it. Are the ball joints expensive to replace...how long does it take. I replaced the struts this year (kyb) and the strut mounts seamed to be ok.
Can I check for a broken motor mount?
Any help is appreciated!
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Old Jun 1, 2001 | 09:52 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Yea, it'd be a good idea to change your ball joints... and yes, they're easy to do on the car. You'll need to rent the tool from a parts store or tool rental place. It's like a big c-clamp with a bunch of adapters. Ball joints are cheap, too - about $15 (US) each. They just press out and press in...
KAM
1992 Trans Am
May 10, 2023 07:19 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
Street Lethal
Aug 14, 2015 08:25 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
