Trouble with piston in caliper
Old May 31, 2001 | 09:53 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I tried installing new pads up front. I can't seem to push the piston in at all! I know its not easy but it isn't budging. The brakes work fine. I bought a piston compressor ages ago, but it broke the first time i used it. Could my problem be that the area where the piston travels is all rusted and it is prohibiting the return? Should i force it in or take the caliper off and have a good look?
Old May 31, 2001 | 10:15 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Things to look at:
1. If you crack the bleeder screw will it go in??? If so your brake hose is probably plugged up. It's a known problem with the front brake hoses... they clog up at the 'joint' where the hose bolts to the strut.
2. If the caliper is rusted up (doesn't want to push in easily after #1) then a rebuilt caliper at Autozone costs a whopping $9.99. Not worth screwing with it yourself for that price.
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old May 31, 2001 | 12:20 PM
Omega's Avatar
Engine: LS1 / LS3
The bleeder screw idea came to my mind as well. I tried to loosen it, but i nearly rounded the head! When i got the car over a year ago, i think the flex hoses were replaced...i will have to check the receipt.
Hmm, $10? That sounds a little too cheap! But if all else fails, i will do that.
Thanks!
Old May 31, 2001 | 01:00 PM
Car: '89 Formula
Engine: 355 TPI
Well, if the bleeder won't come loose then try just loosening up the brake hose anyhow.... either the hydraulics are holding it or rust... and if the bleeder's rusted and stuck that bad it's easier to swap the caliper when it's that cheap.
Either way, with a hose or a caliper you'll have to bleed the brake system.
Old May 31, 2001 | 01:04 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
I road race my Camaro SS for fun, and so I rebuild the front calipers at the beginning of a new season just for the peace of mind.
I just got the Formula, so I would recommend at least getting a rebuild kit for it. Do you have service manual for your car? It'll help if you have any questions.
A black '90 Pontiac Formula with a 305 ci TPI V8, 5 spd, WS6 suspension, 140 mph speedo, 10 disc CD changer & T-tops. Several mods currently on order, with more to follow.
Old May 31, 2001 | 02:48 PM
Omega's Avatar
Engine: LS1 / LS3
I really should actually take the time to look it over well. My winter car (talon) has a bad master cylinder so i have to fix that too.. Both cars have brake problems... not good!
I have a haynes manual but i don't know how good that is with brakes.
How easy is it to push the piston in when the caliper/flex hose is good?
Old May 31, 2001 | 03:31 PM
Car: '89 Formula
Engine: 355 TPI
It should be easy enough NOT to break a tool!!!
I just stick an old pad on the piston and use either a big C clamp or my giant channel-locks.
Come to think of it... if the bleeder is that rusted up that it won't come easy, your car DIDN'T get new hoses just last year unless you happen to park in a salt mine. They would have had to bleed the brakes then.
Like I said, $9.99 at autozone with a $10 core for a single piston caliper. I got one a few weeks ago.
The worst problem I've had was with the hoses on my old '83. If you got one bad one do yourself a favor and change both NOW.
Old Jun 1, 2001 | 08:14 AM
Omega's Avatar
Engine: LS1 / LS3
I think a new caliper is a good idea, i will do that. Also, the passenger side pads have double the wear of the drivers side. The drivers side is the one i am having trouble pushing the piston in. Would that also indicate a faulty caliper?
Thanks for all the help!
Old Jun 1, 2001 | 10:38 AM
Metalifann's Avatar
That probably means that you caliper is hanging up and the seal is not returning the piston to back off the pressure. Also, make sure your caliper bolts are lubed well, that could be a part of your problem.
Your other possibility is that your passenger side might not work correctly and your drivers side works just fine. I would just buy new hoses and calipers. Of all the things on your car, your brakes are definately the most important. Don't try and cut any corners.
Old Jun 1, 2001 | 03:11 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I have been using the $9.99 Autozone Calipers for a month now with no problems at all. I replaced the rubber lines as well. Brakes work like new. Going to do the same on the rear.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC's
*Turbo City Inj Spacer
*Dual Snorker Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
Old Jun 2, 2001 | 07:45 PM
Omega's Avatar
Engine: LS1 / LS3
I went to Kar Parts near me, they were also $10!!! I still can't beleive how cheap they are!!!!
I got all new hoses, pads and calipers... havn't had the chance to get it all back together, there are a few other things that i need to take care of first... looks like new though... cool.
mrbird
Oct 20, 2015 03:43 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
the_hamturdler
Sep 30, 2015 12:50 PM
Lmancha96
Sep 25, 2015 08:11 PM
