How hard to install South Side Machine SFC?
Old May 28, 2001 | 06:11 PM
Taylor92RS's Avatar
They are they weld in type, can't anyone who knows how to weld put them on or is there something tricky to the job?
Old May 28, 2001 | 08:34 PM
Jza's Avatar
Jza
Eeeeeeasy. You just remove the control arm bolt, put the rear end of the SFC in place and put the bolt through. Tack the front end in place, then weld it up. On the passenger side you'll have to slide it between the cat and floorpan first, but other than that, it's a breeze.
If you want to know about the welds in particular, they're solid welds in the front and back, and stitch welds along the rocker panel. Only trick is to hammer the rocker panel against the SFC before welding.
Old Jun 3, 2001 | 01:46 PM
rode51's Avatar
Car: 84 Camaro (weather permitting)
Engine: 434
Make sure you've got your pinion angel before you weld
49 year old kid in an 538 hp 415 84 Camaro
Old Jun 4, 2001 | 09:52 PM
Jza's Avatar
Jza
What's that have to do with it...? The control arms don't control the pinion angle. They control the thrust angle.
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
sonu1975
Aug 11, 2015 08:38 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
