LCA relocate bracket Q's again.
Here is another question for u people. I have a 12 bolt ready to install but I'm thinking of welding on my relocate brackets B4 installation. Is this a good idea or should I weld them on after installation?
1992 CAMARO Z28
STOCK
1992 CAMARO Z28
STOCK
Do it after. If you get it wrong it'll be a pain to cut them off.
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
1986 SC Camaro
B&M Mega Shifter.
Car: 82 camaro SC
What he said, do it after you install the rear. You may not even need them depending on the angle of the LCA's.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkim bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
dbrochard
Sep 25, 2015 04:56 PM
