front brakes...
Old Jun 19, 2001 | 11:30 PM
Rumblin91's Avatar
front brakes...
Left front brake makes a loud click when you are turning the wheel and hit the brake. Checked the wheel bearing and there is no lateral movement or anything. Starting to get annoyed
Old Jun 19, 2001 | 11:56 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Brake pads could be loose, the outer pads have little tabs you are supposed to bend over to make them tight on the caliper.
Could also be the caliper mounting bushings..
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
