freakin creakin
Old Jun 5, 2001 | 12:48 AM
duha0364's Avatar
freakin creakin
i cannot figure it out. I have a wierd creaking popping sound when i stop or get in/out of my car, sometimes when i close the door. It seems to be eminating from the right front. It sort of echoes too so it gives me the impression that the spring is in close proximity to the problem or it may be the problem. The springs are intrax lowering ones and the shocks are kyb 4 way. I have poly bushings and i think everything is tight but not sure now. The sway bar is my next guess but i just wanted to know if anyone else has been here. By the way i am pretty sure the spring is seated in the indent properly. thanks
Old Jun 5, 2001 | 02:14 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I had poly bushings and they squeeked. They could be the problem... grease them and find out. Or get someone to get in and out of the car while you try and locate the noise.
Old Jun 25, 2001 | 10:35 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Every piece of rubber in my suspension including engine & trans mount is polyurethane & the car creaks & rattles a good bit...everything is tight but remember that it ads a lot of stress to the rest of the car...
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
mark406
Theoretical and Street Racing
19
Jan 17, 2002 02:48 PM
86FyrBrd
Jan 3, 2002 11:03 PM
86FyrBrd
Aftermarket Product Review
Jan 3, 2002 10:23 PM
PurplePa$$ionz28
Jan 3, 2002 06:30 PM
JeffC1500TBI
Dec 31, 2001 04:37 PM
