sounds like cv joint...
Old Aug 27, 2010 | 11:44 AM
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
Hey everybody,
I have an issue with my front end. Of course I know we don't have front wheel drive, but the sound coming from the front of mine sounds like a bad cv joint. It only happens when I'm turning and it is on both sides, driver and passenger. I have replaced the front bearings and still have the problem. I don't really feel any kind of sloppiness in steering or under braking. It does pull a little to the passenger side during normal driving so I'm sure I need an alignment, but I don't think that is what is causing the "clicking" noise. I have noticed some tire wear on the outside edges of the tires but I don't know if that is being caused by the "clicking" or the slight alignment issue. I have 127,000 miles on her and the only thing I have ever changed on the front end is the wheel bearings.
Old Aug 27, 2010 | 12:00 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: sounds like cv joint...
Pull the dust cap off the front rotors and see if the cotter pin has been scraping the inside of it.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
